| First 2 runs car ran great... before the 3rd run I went and filled up with supposed super unleaded. Next run it pinged all over the track.... but still idled fine. Before the last run I put in about 3 gallons of race gas... pings were gone, car ran great... but after the run the car idles around 1400-1600. I have... cleaned the tb's, reset the tps, cleaned as many connections as I can get to, replaced the temp probe, tested numerous times for vacuum leaks, the iaa and the air regulator valve both tested fine with the multimeter... Guess looking at/replacing the spark plugs is next. I'm running out of easy things to test. Be seeing you.Tu.frustrated.
Bad spellers of the world. UNTIE! |
